Thompson LCD component to d-sub connection
Discussion in 'LCD & LED LCD TVs Forum' started by sven7278, Feb 28, 2005.
Tags:
  1. sven7278
    sven7278
    Any help here would be very useful:
    I have just bought a Thompson 27LCDB03B and am trying to connect it to my Pioneer DV-575A DVD player using the D-Sub to Component cable on YPrPb channel. The screen is blank. Please help! Many thanks.
  2. ajc347
    ajc347
    Check out this thread. You are not alone in experiencing this problem.
    http://www.avforums.com/forums/showthread.php?t=185310
    Thomson told me that my screen was faulty, however some people have no problem using progressive scan with the supplied cable.
    Have you tried using another DVD player in order to ascertain whether it is the pio 575a which is at fault?
    Have you ensured that progressive scan is enabled in the pio menu?
    If the answer to these two questions is yes then I would suggest discussing the issue further with Thomson customer service and / or retailer.
  3. sven7278
    sven7278
    Many many thanks! I just had to connect the DVD player with scart and on the Initial settings menu select progressive scan. Connecting up then produced a beautiful picture.
    Cheers!
  4. ajc347
    ajc347
    Nice one!!! :D
    Good to hear that you got the problem sorted and that not all Thomson screens are faulty. :)
