Thompson Dlp 912vd Hack
corgi74
To enable multiregion
1. Turn On Player
2. Wait For The Menu
3. Enter The Code 1,6,7,1,9
4. Choose Region (0 For Multi)
5. Turn Player Off
Just done this with mine and it works perfect. Hack is the same as the DTHs 195,212,213 and 231
Optimas Frag
Thanks for that. It does indeed work. Make sure you switch to NTSC output in the player menu however for your Region 1 discs.
