Thompson 32" TV/DVD Hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by ScottGreatorex, Jul 24, 2001.
  1. ScottGreatorex
    ScottGreatorex
    Does anyone know if you can and what it is, cheers
    Scott
  2. Guest
    Hi Scott
    Try this:-
    1. Press “EJECT” and “FAST FORWARD” and “OK” on the front panel of the TV
    2. The TV power light will flash from green to red and back to green
    3. If the DVD player is in Region 1 then it will switch to Region 2. If the DVD player is in Region 2 then it will switch to Region 1.
    4. You only need to switch to a region if the disc will not play.
    5. You can switch between regions as many times as you wish.
    Mike
  3. ScottGreatorex
    ScottGreatorex
    Cheers mate i'll try that
