This Meridian 561 is sending me crazy!Help!
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by pidge22, Sep 2, 2004.
  1. pidge22
    pidge22
    Jul 14, 2004
    1,376
    48
    Near Nottingham
    +29
    Just got my Meridian 561 home and it is sending me crazy its 1.00 am I have to be up for work at 6.00am my problems are.
    Using the volume doesn,t make any difference it is loud! even though the db goes up and down on the Peocessor display.
    The Front Left & Right Speakers don't work with the test signal
    The Front Left & Right speakers actually are coming up as Left & Right subs with a test signal!
    No test signal on my Sub
    I can't get anything on my Tv (plasma) even though I have connected the composite lead.
    i have managed to down load new settings from my Pc but I made no difference.
    I see someone mentioned a re-type to set the processor back to default but cannot find instructions on how to do this.
    Any advice woul be appreciated.
    Pidge22
  2. suzywong
    suzywong
    Nov 6, 2003
    261
    19
    Southampton
    try page 67 of the user manual
  3. chrisgeary
    chrisgeary
    Jul 23, 2003
    2,672
    Newbury
    +215
    i would recommend setting up your 561 using the pc interface.. its much easier than the front panel!
    firstly, i am presuming you using all analogue speakers - therefore you are limited to using 5.1 channels. so set:
    mains to small analogue
    centre to small analogue, movies (and music if you wish)
    rears to small analogue
    sides will be greyed out
    sub to one, mono.
    this should give you a good starting point.
    you then connect your main speakers amplifiers to mains/sides, centre to centre, sub to sub and rears to rears.
    as far as i am aware, the only time the volume control wont work on a 561 is if you try to use a digital output to an external DAC. whilst i have never done this myself, i have been lead to believe that this signal is intended for meridian DSP speakers only which have digital pre-amps in.
    hope this helps!
    Chris
  4. pidge22
    pidge22
    Jul 14, 2004
    1,376
    48
    Near Nottingham
    +29
    Thanks for all your help the 561 is now configured and sounds awesome.
