Welwynnick
This is the HDMI/DVI/HDCP interface for Barcos that everyone has been talking about, and which MadMrH has been so smug about after getting a couple of units from the previous batch. It's the real McCoy for any HD source, and there is also a unit for Sony projectors. I don't understand all the port 3 / port 5 issues for different projectors, so Andy had better explain that, though he may be slightly distracted by putting all his new hardware together......FS: Barco DVI/HDMI(HDCP) input modules
Due to high AVS members requests, I've decided to build a new and 'larger' batch of the DVI/HDMI(HDCP) convertor module for Barco CRT projectors serie (so-called "BG-DVI"). This new batch will be done by a professionnal third party production company. So, the complete batch delivery time will be extremely fast (15 days).
Work for Barco projectors series :
BG800, BG801, BD808(s), BG808(s), BG1208(s)(/2), BG1209(s)(/2), Cine 8 Onyx), Zenith Pro 1200, Cine 9, Cinemax
Specifications :
- DVI-D input (100% digital). A HDMI -> DVI-D cable can be use to connect to an HDMI source.
- RGB 4:4:4 (8 bits) digital input (every HDMI source MUST be RGB 4:4:4 compatible).
- Compatible with non-HDCP or HDCP sources.
- Directly connect to Barco "Comm Port" and "PORT3". Easy to install it within 5 min. (plug&Play).
- 10 bits 175MHz triple video DAC - Inter-DAC : 2%
- Output RVB-H/V video analog signals (0,7Vpp over 75 ohms impedance)
- Ultra short Analog links (<2 cm) on the BG-DVI PCB for optimal quality.
- DVI video bandwith in RVB outputs : 25-165MHz
- Maximum resolutions : UWXGA (1920x1200) at 60Hz or SXGA (1280x1024) at 85Hz Computer compatible (PC, Mac)
- HDTV ready (480p/576p/720p/1080i/1080p48/50/60 compatible)
- HD-DVD and Blue Ray Disc players compatible (see : http://www.avsforum.com/avs-vb/show...27&page=7&pp=30 post #189)
- HDCP compatible with embedded keys loaded.
- Energy management : DVI et VESA DPMS compatible.
- Ultra low power consumption in Standby (3,5mA)
- Maximum power : 0.4A under 5V (at 165MHz pixel clock)
- On-board DC/DC converter (30V to 5V) with extra-low EMI signature
- Green LED to display active digital link.
- Low cost solution – Single IC solution
- Small size : 75x56mm black cabinet
- Installation : the BG-DVI module is DIRECTLY screwed to the back of the PJ (where COMM port and Port 3 SUB-D plugs stand). So no coaxial run and shortest RGB analog video link as possible (also HDCP rules compliant, i.e. no end-user access to decrypted analog video) Once screwed, this module become "a part of the PJ itself".
The BG-DVI english user Manual is available in here
The BG-DVI french user Manual is available in here
- Professional factory made (mass-production) using pick/place and reflow/wave solder pro. equipment.
- Quantity available = 100 (already around 60 people in waiting list)
- Availability = Mid/End of September 2006
- Price = 220 Euros including shipment cost (International registered letter)
John
http://www.avsforum.com/avs-vb/showthread.php?t=703549
No need to thank me. Much.
Nick
