This is driving me mad!!!!!!!!!!!
Discussion in 'LCD & LED LCD TVs Forum' started by Spursman, Jul 7, 2005.
Tags:
  1. Spursman
    Spursman
    Jun 28, 2005
    403
    +24
    I want to buy a 32inc LCD screen. it has to be HD ready.
    I really dont know which one to go for. Dont want to spend more then £1,000.
    Any suggestions??
    i would prefer 37inc LCD but there a bit to expensive at the moment, how long do you think it will take to lower in price? is it worth waiting a bit?
  2. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +122
    I think you'll struggle to buy a 37" (decent one that's HD) for anywhere close to £1000 even in 6 months time.
    My fav panel from the previous generation is the JVC - here's the best price I could find online.
    If you can throw another £350 onto the budget, you'll pick up the current gen model - DS6, although the Panny DX500 is supposed to (according to one member's postings here) to be the current balons d'un chien - or dog's danglies in English, which is similarly priced. At that point, I'd also consider the Sharp Titanium to make it a 3-way fight.
  3. Chris The Ninja
    Chris The Ninja
    Mar 10, 2005
    176
    +3
    check out acer AT3201W for £800 at dabs, has it all
  4. GaryB
    GaryB
    Nov 12, 2002
    5,381
    St Albans
    +1,292
    The LT-32C50 doesn't do 720p@50Hz and doesn't have an HDMI socket so it can't really be considered HD Ready. You would have to find the extra and go for the DS6 to get full compatibility. There is another thread running on the DS6 with contributions from several people who have bought one.
