This has to be a new Sky+ glitch - doesn't it?
Discussion in 'Sky Digital TV Forum' started by Faust, Apr 17, 2005.
  1. Faust
    Faust
    Dec 21, 2002
    3,231
    UK
    +670
    Just discovered a truly bizarre glitch with my Sky+. I have never really used Sky Active, however, I was just looking at different things on the system today, and having selected Sky Active through services thought I would check out a couple of the listings. However, when I scrolled to one of the thumbnails and pressed select my Sky+ box shuts down and goes into standby. When I restart and check signal it says Line 2 not locked, but then immediately re-locks starts with the welcome to Sky page and starts looking for EPG listings. This happens every time I repeat this procedure. The LNB is fine (only replaced two weeks ago) signal strength and quality up in the high 70's. In all other respects the box works fine, dual record, single record, back to back record, instant rewind, etc. etc. Is this a totally new glitch or has anyone else experienced this fault?
