This device cannot start. (Code 10)
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by RecordablDVDfan, Sep 11, 2004.
  1. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    I have a JVC D-31 camcorder but no way can I get the thing to connect to my pc with XP pro. All I get in devbice manger is :-
    I can get it to work with an SP2 version of windows on a old Thinkpad laptop (firewire PCMCIA card) I do not wish to update to SP2 on my main pc. There must be an Microsoft fix on this (not that I can find one) as I've read others having similar problems. Can anyone help please ?
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Probably not much use to you but I had the same error in device manager for a DVD writer a little while back.
    It turned out to be some new DVD authoring software I had installed that was causing a conflict with other burning programs & the writer.
  3. Crocodile
    Crocodile
    Nov 4, 2002
    15,530
    +4,718
    Have you tried the firewire card manufacturer's site for an updated driver?
  4. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    It's a texas instrments make, looked on the TI site but nothiong on there it seems. XP should find and install this withot problems so I guess it's the card in some way ?
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    I can't remember if it was JVC, but I seem to remember reading that there were problems with firewire cards with the TI chip set and a certain make of camcorder. Might be worth getting another (non TI) firewire card to try.
    Mark.
  6. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    The Canopus ADVC-100 used to have problems with some older TI firewire cards. Newer generations should be Ok though.
  7. Crocodile
    Crocodile
    Nov 4, 2002
    15,530
    +4,718
    I doubt that that card is made by TI, just the chipset. If the card itself doesn't have a manufacturers name on it, it may have a model number printed on it. A Google search on this model number or on the TI chipset number may throw up a manufacturer who may in turn have a driver.
  8. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    That's what I meant
    :lesson:
    I must be clearer in my replies......
