"This CD cannot be imported"
Discussion in 'Headphones, Earphones & Portable Music' started by targetdummy, Apr 26, 2005.
  1. targetdummy
    targetdummy
    Mar 26, 2005
    15
    3
    Sheffield
    Just in the middle of importing my CDs into SS3.0 and came across one CD that comes up with the error:
    CD in question is Jane's addictions "Strays".
    Anyone got an idea of how to get round this?
    Thanks. :(
  2. AMc
    AMc
    Nov 20, 2000
    6,947
    Near Norwich
    +3,552
    Can't help you with SS but iTunes happily imported my copy protected UK CD release of 'Jane's addiction : Strays' into unprotected 196Kbs MP3 without a glitch.
    iTunes is a free download (in case you didn't know)
  3. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Thats funny I have that album and it copied with I-Tunes!
    However the first Kings of Leon album wouldn't. For that reason I will not buy anymore of their stuff.
  4. targetdummy
    targetdummy
    Mar 26, 2005
    15
    3
    Sheffield
    AMc, thanks for the info. I downloaded iTunes and imported the album in mp3 format, then got SS to convert to ATRAC3+ and it is now on my HD3. I guess I'll keep iTunes in case I encounter any more copy protected albums.
    Thanks again! :thumbsup:
  5. youngsturb
    youngsturb
    Rip the CD to MP3 format using audiograbber (or similar) then import the music from the files created. I have had this issue a few times and this is the easiest way around it that I can find.
  6. jamesb
    jamesb
    Jan 29, 2002
    15
    audiograbber woundn't work for my kings of leon cd..
    another application i came across was isoBuster which
    worked fine on this cd.. read and copied the songs to wav files
  7. GETanner
    GETanner
    Mar 11, 2002
    577
    +76
    I used Audiograbber + LAME with all my CDs.
    With both of the Kings of Leon albums, a quick boot into Safe mood did the job.
    Hadn't thought of using ISObuster. Will give that a little try later.
    G
  8. img
    Jan 22, 2004
    586
    +16
    i might be wrong but on some cd`s when u put them into your cd drive it auto installs a service that stops u ripping the tracks the cd. you can if you are having problems disable the service and when u insert a cd hold shirt i believe will stop it autorunning.
  9. Darren Blake
    Darren Blake
    Apr 28, 2003
    626
    Norwich, UK.
    +15
    I have a digital optical link from my CD player through to my amp and into my PC via a cheap Trust Sound Expert Optical card (although you could go straight from CD player to PC).
    If all else fails, I jusy play the CD and use something like Nero SoundTrax to rip it in real-time.
  10. djarend
    djarend
    This problem always occurs with cd's which are of emi or virgin. I Use Music Match to rip them, goes well, but i can't understand why they still copy protect cd's (and i am even an owner of a cd-shop, can you imagene, haha) because there's always a way to rip a cd
  11. FifeFlyer
    FifeFlyer
    Feb 12, 2005
    Fife, Scotland
    Had the same problem with a couple of CD's but running SlySofts "AnyDVD" cured the problem and the CD imported ok. (AnyDVD removes copyprotection on CD's)
