this any good ?
Discussion in 'Plasma TVs' started by tabs, Apr 25, 2005.
  1. tabs
    tabs
    Apr 3, 2005
    1,918
    warks
    +130
  2. mr_incredible
    mr_incredible
    It would certainly do the job without question. Whether or not it does a GOOD job is another story. Usually these scart switcher boxes do ok and as long as it carries RGB then you should be fine. Obviously its better to go straight into the plasma if you can but with the limitations on the number of scart sockets on plasmas its impossible. The only way to know is to buy and try. If your picky about your picture quality then you will notice a slight difference, if not you should be happy. Have you not got component out on the dvd? That would be the best way to get that guy going!
