Third time lucky
Discussion in 'Plasma TVs Forum' started by danny-p, Nov 21, 2003.
  1. danny-p
    danny-p
    Hi there,
    Ive recieved my new supra mains plug for my plasma and to my shock comes standard with a huge "hampster ball" fitting @ the end of it so it wont physically fit into my panny plasma because of this!!!.....so i used it for my DV27 instead.
    So i was recommended a Russ Andrews Yello which i was told would fit.....but again the standard shape for the connection is fine but the cable/pin hider is stupidly oversized again and is catching on the underside of my plasma again........Can anyone please recommend me a decent mains cable that will definately fit into a panny 4 series plasma..
    My budget is £50ish
    Danny
  2. deman77
    deman77
    Aug 20, 2003
    263
    16
    London
    how annoying.
    is there gonna be the same problem with PW6?
    Does new mains cable for the screen really make a difference?
    I bought one for SKY+ but didn't notice a difference?
  3. danny-p
    danny-p
    apperently depending on source quality will vary......On my dv27 picture is a minute improvement but sound is alot more detailed....this is with the Supra mains........
    Havent tried sky?
    Just out of interest what plug have you bought for sky?
    Didnt know there were any of that type thats all
    Danny
  4. danny-p
    danny-p
    With the help of some of the peeps on this site i may soon be able to try connecting up my plasma
  5. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
  6. deman77
    deman77
    Aug 20, 2003
    263
    16
    London
    Mine is from Mark Grant, he is a forum member. He'll make any length you need for SKY and plasma, plus he makes component cables. Highly recommended by StooMonster.
    The cable did improve the sound, but I can't tell with the picture, that's why I'd like to find out whether it makes a noticable difference on plasma picture b4 I get one, as plasma cables are considerably more expensive.
  7. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    I use Russ Andrews Yellow mains cables on my Pioneer plasma and DVD player. I had no difficulty at all to insert them. I would have thought there should be no difference on Panasonic. You should also note more difference in the performance after the cable has been fully run in .... 100 hours or so.
  8. jmack
    jmack
    i`m using a russ andrews yellow on my toshiba /panny 4 series
    all workd fine
  9. danny-p
    danny-p
    Sorry ,
    I was recommended a R A Yellow which looks identical to the Black Rhodium Supermains 13 13A/IEC 1.25M which i have and doesnt fit!!
    Is the tosh casing definately the same as panny 4 as i know the internals are identical?
    And last but not least is the R A Yellow the same physical size as the Bl rhodium?
    Very wierd and annoying if it is as @ over £50 a shot its coming to the point where the standard cable is dammmmm good...lol
    Danny
  10. danny-p
    danny-p
    Just to add/ clarify things.....it will fit into the connection just that the panny4 has an annoying low ledge above the connector which prevents it going in??
  11. danny-p
    danny-p
    So will the russ andrews Yellow definately work/fit?
    If so i'l order one now.
    Supra went into the dv27, other one into my sky+ via adapter and hopefully yellow will work?:confused:
  12. jmack
    jmack
    cant get to the back of mine as its coverd. but it defo works , you just need to find out if the panny 4 and the toshiba are the same.
  13. danny-p
    danny-p
    Hi ,
    Can anyone please clarify this problem regarding yellow connection to pannt4 series?
    Danny
  14. danny-p
    danny-p
    Sticking with the standard mains cable it is then.:mad:
