Quantcast
Thinking Van Damme Blue, anything else to consider?
DannyBoy73
I'm looking at buy a 100m of speaker cable for rears and 4 ceiling speakers.
I'm thinking about the Van Damme Blue 2x2.5mm (approx £240 inv VAT), the longest run is approx 15m.
Anything else to consider?
Would there be any improvement over more expensive cable? Maybe QED Silver Micro?
Open to any other suggestions.
Dan
DannyBoy73
Joe Fernand
AVForums Sponsor
'Would there be any improvement over more expensive cable?' - price is no indicator of a decent cable or the 'sound' it will deliver.
The Blue Series cable is of a suitable gauge and consistent construction to suit most AV/Home Cinema Systems and being 'twin-axial' makes it an easy cable to install when you have to thread it into a room.
Have a look at our webshop - https://tmfsolutions.co.uk/product/vandamme-blue-series-loudspeaker-cable-2x2-5mm/
Joe
DannyBoy73
Cheers Joe, very helpful as always.
Order placed on your site :)
Similar threads
