cheeseandtoast
To make use of some corner space, I made a corner stud wall, the face of the wall will be sealed by MDF sheets. Once closed im hoping never to back in. On the front i'm mounting a TV, two SAT speakers, and a center.
For that reason i wanted to ask what would you do to ensure you wouldn't have to open Pandora's box.
Any other thoughts would be much appreciated.
- I'm running all the power, speaker cables, av cables prior to sealing the unit. When i come to connecting all the AV unit it will be a case of plug and play.
- Holes have been made for cables
- TV bracket is mounted
- Cabinet lighting is installed.
