Thinking on bulding HTPC. Help Needed...
Discussion in 'Desktop & Laptop Computers Forum' started by jrosado, Dec 19, 2004.
  1. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    Hi:
    I'm considering bulding an HCPC. The main reason it's because the Panny DVI board does not handle PAL signals very well, so i'm going to a PC to take full use of it.
    The main use will be dvd-video, divx, mp3 and cd music. so far i have a few elements, but also some indecisions. I'me new to this stuff, but here it goes the items i've pickuped:
    Asus Terminator 2 chassis
    Asus ATI 9200 graphics Card (I've chossed this one because there is no fan)
    80GB serial ATA Hardisk (samsung or other)
    Asus DVD-ROM model DVD-E616P2 . This drive is quiet and easy to make multiregion
    2* 256MB, Kingston DDR400
    No my doubts:
    Which processor: Pentium or Celeron? Will Celeron be enough? wich speed? The less heat it generates, better, because i want it to be very quiet.
    Altought the motherboard has sound in board, the digital output is on front. Wich sound card should i choose? The sound card must have a digital output.
    Any sugestions are welcome.
    Regards,
    J. Rosado
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I'd suggest you go for an ATI 9600 SE, also fanless but slightly better MPEG decode support. Samsung disks are now a dubious choice, they switched motor suppliers in the summer and reportedly the new ones are nowhere near so quiet, Seagate Barracudas are perhaps back in pole position again.
    A Celeron will be fine if all you want to do is hardware-assisted DVD playback, anything more such as post-processing using FFDSHOW, software-only WMV HD etc. a P4 will be needed IMO.
    No thoughts about a soundcard really, I use on-board, but the M-Audios seem to be popular for HTPCs.
  3. groovyclam
    groovyclam
    Mar 28, 2004
    202
    As KraGorn says, definitely upgrade to the ATI 9600 SE graphics card.
    Also 80G might be a bit small for the HD - Windows and apps take about 7G and 1hour of Mpeg2 is about 2G, 1 hour of DivX/XdiV is about 0.5~0.8G and then there's all your mp3s and photos. If you can afford it go for a 160G drive - I just about cope with that.
    You'll definitely want the HD space if you fit a digital terrestrial TV card for PVR recordings.
  4. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    Hi:
    Thans for all the answers. I'l guess i'm going toa P4. As for the graphics card, 9600SE would be a good choice, but the asus model does not seem to be fanless - at least in the photos in asus website; maybe another brand?
    As for the HD, 80GB will be enough for me. I've allready got 60GB+160GB in my main computer. I've also a 250GB which i placed inside a external case with USB2.0 and firewire interfaces. Also, any recordings will be made on my main computer.
    Kragorn: what is the soudncard of your mainboard? Were can i see the specifications of that M-audio? I was considering the Sound Blaster Audigy 2 Zs or the Zs platinum, that has a remote :)
    also, for now, and for controling the PC, i was considering a wireless keyboard and mouse (this one optical).
    Regards,
    J. Rosado
  5. groovyclam
    groovyclam
    Mar 28, 2004
    202
    As far as I am aware, all Radeon graphics cards are built to the same speck, so all 9600SE's should be fanless. Are you sure you are looking at an "SE" - only the SE and the plain 9600 ( no suffix ) are fanless. The other types of 9600 card have fans. The SE should be about £40 and the vanilla 9600 ( no suffix ) about £70.
    The Sapphire versions of the 9600SE and 9600 are definitely fanless and can be got from dabs.com ( and probably other places )
  6. groovyclam
    groovyclam
    Mar 28, 2004
    202
  7. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    Ok... If you say they are fanless, i belive you ;) . Just that the pictures in Asus website don't show it like fanless: Asus 9600SE . I will have to see it at my local pc store.
    As for the output, as i said in the beginning, i'm going to use the DVI output to connect to my Panny plasma :thumbsup:
    Regards,
    J. Rosado
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
  9. gpender
    gpender
    Sep 21, 2002
    272
    Soundcard wise I'd go for an RME......... M Audio are better than the creative cards but they still don't get near the RMEs. This could be regarded as stating the obvious given the difference in price, but I make the coment safe in the knowledge it's worth spending a few quid more on the RME. Check out www.millennium-music.biz for prices (they are the cheapest around) they've got pretty much everything on there....I don't know whether they ship to Portugal though
  10. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    Hi:
    Thanks for all the answers. Having in consideration that the decoding work will be done by my receiver (except for dvd-audio), should i really consider such expensive cards?
    Regards,
    J. Rosado
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    IMHO no, the RME would be a great card for PC-based audio but is way overkill for SPD/IF to a receiver IMHO. :)
  12. petrolhead
    petrolhead
    Mar 29, 2002
    4,485
    71
    Newcastle
    +82
    Has anyone thought about some of the newer purpose built PCs like the Hi-Grade or EPC
    Has anyone bought one
  13. Ridcully
    Ridcully
    Feb 16, 2002
    334
    28
    +29
    Sapphire 9600 is fanless if you want to go up a spec. Alternatively you could try the 9600 ultimate which is also fanless.
    KraGorn, interesting comment about the hard discs. Was think of getting a new one so will have to take this in to acccount
