Thinking of renting a TV
Discussion in 'LCD & LED LCD TVs' started by rossyl, Aug 9, 2005.
  1. rossyl
    rossyl
    Jul 25, 2004
    158
    16
    London
    Looking to spend £40 a month max for 6 months, and nothing less than 32" on an LCD.
    Any tips...I've looked at
    http://www.martindawes.com/
    http://www.rmtv.co.uk/
    Don't seem to be any others.
    I'm thinking of doing this on the basis that the £240 I will spend will be recovered when i buy a Hi-Def LCD TV next year. I think that prices will drop generally. Therefore, taking into account the £240 I am spending now, I will pay the same amount or less next year and get a better TV.
    I think much of the technology out now is brand-spanking new and hence the price is high. Plasma's for example have dropped in price over the past two years, and LCD's increased in size and dropped in price over the past year.
    OPINIONS....?
    Ross
  2. igauk
    igauk
    Apr 8, 2005
    132
    Glasgow
    +6
    Well, you forgot Boxclever (www.boxclever.co.uk) formed out of the ashes of Radio Rentals and Granada.
    Not sure about your logic. Rent for six months = £240, so if prices fall £300 in six months, you'll have saved £60. If prices only fall £150, you'll have spent an extra £90 compared to just buying the TV six months ago.
    Of course you could just rent the TV full stop, upgrade when you want or the technology changes and get it fixed or changed if it breaks down for free. I doubt you'll be able to rent just for six months though, when I worked for Radio Rentals the standard contract was usually 12 or 18 months. Rent for a shorter period and you tend to have a restricted choice and higher payments.
  3. domtheone
    domtheone
    Nov 23, 2004
    13,610
    Nottingham
    +2,357
    Blimey
    You know I considered this once but things have moved on since the time of £9.99 a month for a half dcent telly from Radio Rentals way back in the early 90's??:eek:
    £60 a month for a decent, say 32" LCD.
    Outrageous :nono:
  4. akki007
    akki007
    Mar 23, 2005
    1,693
    +154
    Surely nobody rents a TV anymore, surely! Just buy a 20" LCD for now if you want to wait for better tech in the future.
    Renting = chucking your cash in the bin.
  5. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    I thought that there were also min rental terms as well probably 12-18 months. :thumbsdow
  6. getdownmonkeyma
    getdownmonkeyma
    Aug 25, 2004
    196
    +7
    Rental agreements usually tie you in for a minimum of twelve months.
    I looked at renting a Sharp 32GAs, but at £95 per month I said no thanks!.
