Thinking of going down the CRT root
peve3
At the moment I currently own a Hitachi TX100 LCD projector and I am very happy with the projector, I run .ts HDTV films from my PC into the LCD projector and am happy with the results.
But with the advent of the Xbox 360 I am thinking of upgrading my projector as I want something with a bit more depth. I was originally going to wait for the latest range of LCD's like the Sony HS51,AE900,TX200 etc but having read this link:
http://www.curtpalme.com/CRTPrimer.htm
I am thinking maybe I could get an absolutely amazing picture!!!. I currently have a dedicated Home cinema room with an 80" projector screen and feel adding a CRT projector would compliment the room
I am quite a technical person and as such am willing to give the CRT tweak-a-thon a go.
Please could people advise what would be the best CRT projector to purchase, please understand I know next to nothing on CRT projectors apart what is in the above link and I don’t know anything about scaler either.
I do have a pc hooked up but don’t know how I would go about connecting an Xbox 360 up to my pc in order to use it as a scaler.
My budget would be in the region of about £1500 with a 720P image being paramount, I would also like information on the cost of replacement bulbs if that’s possible.
Would CRT give me a big enough image quality to warrant the time over my current projector? Or should I just go down the easy route and purchase the next range of LCD’s.
Thanks in advance for any help.
PS: If anyone with a CRT projector in the Basingstoke area would be willing for me to have a viewing I would be most gratefull.
Jeff
I'm in Basingstoke, I have a Barco 1209s, send me a PM if you want to take a look.
Jeff
Mad Mr H
Jeff - a 1209s for £1500 SOLD!
(Yes I understood what you meant.....)
Peve3 - go see the 1209s - this is a real high end crt and well worth a view even if you decide crt is not for you.
I also think you should consider your price a little (not a lot) more.
Good DLP's will start around £2k with all the inputs you might want and features which will help in a good picture.... as a result I think you should consider a slightly higher budget as you are after all looking at a much higher quality picture with crt.
Go see the 1209s - tell us all what you think - 99.9% of people here will welcome your honest opinion even if you dont buy one.....
curts site will give you a great starting point to see many different models....
rob12770
tweak-a-thon..hmmm
i have found all the talk about crt,s needing constant adjustment to be untrue, they are not as demanding as you would think, IMHO
rob :hiya:
Mad Mr H
You are right,
Most of the tweaking if you ask me is people who dont understand how to do it correctly in the first place.
Or a room with massive temp changes will do it - but then if set up correctly this should not be an issue.
tweaking is also required if your unit is not 100% well, a nasty e bay purchase will need help!
Most pj's are stable and should be left alone.....
Playing and tweaking just takes up time when you are meant to be doing other things!
I tweak! but I am trying things off the usual track to test results......
thats my excuse ;)
peve3
Well I went over to Jeff’s house today to have a look at his setup, and all I can say is WOW it truly is a superb installation and I can see a lot of time and money has gone into getting it looking and sounding perfect. :smashin:
We watched a few scenes of the new batman film and it was clear straight away why people think CRT gives the best image quality from a projector, very detailed and insane blacks made the overall image have a great sense of depth. Then Jeff showed me some football from his Sky + box which was just as impressive and smooth.
Only thing that I felt might put me off is the shere size of the projector unit, i was clearly not expecting it to be as big as that. Not that i don't have the space it was just a bit overwhelming at first.
It has definitely given me some ideas about what route I want to go down, but I think I may hold off a few years now as with the advent of commercial HDTV upon us I think we will see some truly stunning projectors coming out for a modest amount of money.
So im going to hold out and see how the whole thing gels.
Thanks for letting me view the installation Jeff, top setup and top bloke :thumbsup:
Mad Mr H
the 1209 is without question the largest of the BARCO series.
(909 might be bigger never met one!)
1208 has same case but 8" tubes :thumbsup:
the 808 case has smoother lines
801/800 is smaller
701/708 Much smaller
Selecos similar to the 701/8 ;)
and were more designed for home cinema use
nice silver case, sexy lines mmmmm!
Sleep on it, then buy a crt and never look back.....
Jeff
Glad you like it. :thumbsup:
