Thinking of getting 2nd Sky+ Box.
Discussion in 'Plasma TVs Forum' started by sharper, Sep 23, 2003.
  1. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    Having trouble working out how to connect it to a Panasonic plasma 4 without using SVID via Yami A5. Would rather go RGB ‘MAYBE’ using the pass through on Sky+ box but not sure how the switching would between both Sky+ boxes.
    Current mirror sub is a Sony Sky box connected Svid via Yami A5.
    Current Sky + is connected RGB through JSTech RGB-VGA converter
    DVD Pioneer 525 (getting old) through JSTech RGB-VGA converter.
    SVHS connected Svid via Yami A5
    help?
  2. jont
    jont
    Apr 8, 2002
    4,269
    near Aylesbury
    +553
    The RGB bypass on the existing sky+ would just pass whatever signal it is given .. ie either the 'live' feed (but why would you need that when you already have a live feed on the existing sky+) or the 'recorded' feed which presumably is the reason you want to get a second box ?
    Jon
  3. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    see you have 2 Sky+ howw do you watch yours.
    if some in the house want to watch Sky+ A upstairs and I want Sky+ B on the plasma or the other way round it wont work with passthrough. correct?
    I would need to have a Switch at the plasma end. or use the Svid
    agree?
