Thinking of buying the following .....
P
Paulo88
Hi All,
I would like your advice on the following proposed purchase. I'm trying to get as much as I can for £1400. Tight I know !!
I can add other essentials as I need them. Here goes......
I was thinking of buying the Panasonic TH37PW7 £1099 from Richer Sounds.
I need to connect to that SKY TV, DVD and a PS2. Do I need to get a Scart board for each device ?
Can I just buy one scart board then buy a cheaper Scart distributer, this will mean only 1 scart cable going to the plasma.
I would then for the time being wire the Plasma to the DENON stacking system I have in the front room for the sound. (if possible!).
Suggestion please ! :confused:
Taz69
I think you would be better off using a JS Labs RGB to VGA box for the sky ( better picture from what I have read, and then buy a board for your DVD ( component is best if poss) then you can use the ps2 aswell if you buy a Component/Composite multi board.
You can pick up a JS labs in the classifieds most times, if this helps the budget, the board can be found at plasmaware i think for about £80
Hope this helps
Taz
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
