thinking of buying rear centre speaker and need some advice
Discussion in 'Home Cinema Speakers' started by matt bellamy, Jun 21, 2004.
  1. matt bellamy
    matt bellamy
    Jun 19, 2004
    230
    16
    hi,
    I have a yamaha amp capable of dts-es 6.1 sound and currently have 5.1 speaker setup. The speakers I have are Acoustic solutions with the big floor standing front speakers and large center and rears. I have read on the forum that most people recommend buying the same make of speakers instead of a mix and match approach but would it be ok to use a satelite speaker (one used for all-in-one home cinema packages) rather than a large wooden type speaker for the less important rear-centre spreaker or do I need a speaker similar to my left & right surround speakers.
    thanks
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I dont think there is any hard or fast rule about that. Some people use centre's as rear centres and some people use normal speakers. Ive used both and not really found either has any advantage over the other. The only difference is that I was using bipoles as the 3 surrounds not direct facing speakers.
  3. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    I think that it depends on what you are using the centre rear for. If just for effects then a 3rd rear speaker would do, if for speech then a 2nd centre speaker is better.
    Is this an opportunity to upgrade your front centre and use your original front centre speaker as a rear center?
  4. matt bellamy
    matt bellamy
    Jun 19, 2004
    230
    16
    It would be used for effects so will probably go for a 3rd rear speaker. Does it need to be similar make and size to my other 2 rears?
  5. uk_jih
    uk_jih
    Mar 17, 2003
    175
    +6
    I was always told that it was better to use the same drivers.
