Thinking of buying a AVR300, but will it match my B&W 600 speakers?
Discussion in 'Arcam Owners' Forum' started by Duster, Dec 16, 2004.
  1. Duster
    Duster
    Dec 4, 2002
    421
    UK
    I'm thinking of buying a AVR300, but i'd like to know will it match my speakers?
    Front left & Right-B&W 603 S3
    Cen- B&W LCR 600 S3
    Rear L & R & Cen- B&W 600 S3
    Sub B&W ASW 600
    The use would be 70% music 30% DVD
    Thanks for any help
  2. booktrunk
    booktrunk
    Feb 6, 2004
    602
    Leicestershire
    +3
    Yes it will be fine.
    I've had 602s and 7NTs with an FMJ A22 and it sounded darn good. Your 603s should be fine.
    If you are only 5.1 it would be nice to use the other two channels to bi-amp which will probably help the sound out as well.
    EDIT: DOH!! You say 6.1 so bi-amping is out of the question, but as an experiment it might be worth trying 5.1 and bi-amping the fronts. As you are more intersted in music than the DVD side of things.
  3. Hifi addict
    Hifi addict
    It will sound great ! Arcam and B&W are a great couple !
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Agree! I previously had Arcam 8r/8p Bi-amped into 603s and the sound was IMO excellent. As stated above B&W and Arcam work very well together, and bi-amping the 603s does make a big difference if you can live with only 5.1 or else get another Arcam amp to do it.
    Mark.
  5. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Thanks Guys,
    Thats great news :thumbsup:
  6. malcolm mccabe
    malcolm mccabe
    Have B&W/Arcam combo - sounds fantastic, added a P90/3, which has taken system to a new level. With the AVR300, you can use the two extra channels to bi amp the fronts - although it depends on what type of music you listen to, I doubt you'll be disappionted.
  7. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Ok, Ive ordered a AVR300 from my local dealer :clap:
    Thanks for the help :smashin:
  8. Duster
    Duster
    Dec 4, 2002
    421
    UK
    ooh, by the way,
    Which speaker cable do you think I should use?-
    Ive got QED X-Tube 400, QED X-Tube 300, & QED Silver Anniversary,
  9. Hifi addict
    Hifi addict
    thrillseeker !! ordering without listening.... but i think you will really like it
  10. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Yes I know, :suicide: It's the only way I can get one, as my local dealer doesnt really stock Arcam, :( , but he did give me 10% off. :cool:
    as I buy all my gear off of him.
  11. Hifi addict
    Hifi addict
    and with some luck, you will get it before newyears eve. Oh boy, what a LONG night it will be :D listening to you new setup :)
  12. bluesfan
    bluesfan
    Feb 10, 2004
    303
    16
    Yorkshire
    I have 603s and silver and they're good for bringing out detail. I'm partnering with A90 but 300 is fine. The 603s are a bit boomy for my liking so look anything that controls the bass.
  13. jonan73
    jonan73
    Has anyone tried this amplifier with CM4, CM2 & CMC ?
    My amplifier is not powerful enough and I need to upgrade my dvd player/AV amplifier.
    Thanks for the info!
    JOhann
