Thinking ahead - Xbox 360 and component switcher
Discussion in 'Cables & Switches' started by Krill, Aug 17, 2005.
  1. Krill
    Krill
    May 19, 2005
    1,371
    Market Harborough
    +184
    I currently have a Toshiba 32ZP48 TV which is lovely. It's connected to a Denon DHT500SD via a component video cable.
    Now I have ordered the Xbox 360 premium package which comes with a Component HD AV Cable. Rather than having to pull the cables out of the back of the TV all the time I'd like to look at a component switcher to allow me to switch between using my DVD and the new Xbox though my Toshiba TV.
    Would something like this suffice, a JS-Tech Master COMPONENT Controller http://www.js-technology.com/produc...id=49&osCsid=a346441d47cf922b6e3ffbec6ac3ea00
    Do you think it would effect the picture quality?
    I appreciate the Xbox 360's are not out and this is partly guess work but I thought it would be a similar process to that of a running a standard Xbox and DVD with component and sharing it so I hoped some of you could point me in the right direction.
    Any help or comments are appreciated.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,744
    The Borders
    +3,085
    Krill
    I think you'll have to be the Guinea pig - I'm not sure if Dr John (of JS Technology) will say his box has the bandwidth to switch HD or not; if it does then its a good bet and relatively low cost compared to the alternatives.
    Best regards
    Joe
    PS Your sure a two input switch will suffice in the long run?
  3. Krill
    Krill
    May 19, 2005
    1,371
    Market Harborough
    +184
    Well I have looked at other alternatives but am not sure on whether they are suitable?
    I have seen something called the AVT-5842 for £80 at http://www.scancom.ltd.uk/products/avtoolbox/avt-5842.htm and I have also noticed lots of people have reccomended the Zektor HDS4. Would these be more suitable and what are the costs usually associated with the Zektor?
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,744
    The Borders
    +3,085
    Hello Krill
    The Zektor HDS4 and HDS4.2 are passive switching designs that deliver very low signal degradation on signals up to and including 1080P.
    You have a four Input switcher with full IR or automated control - so quite different from the other solutions your considering.
    UK SRP on the Zektor HDS4 is 240.00.
    Joe
  5. Monkeyboylee
    Monkeyboylee
    May 4, 2005
    707
    Harrogate
    +21
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,744
    The Borders
    +3,085
    Monkeyboylee
    What is the Whitedog passive YUV Switch more like?
    I take it you mean its price is more to your liking :) unfortunately there is no Tech spec available to indicate how well it will work or wont.
    Best regards
    Joe
  7. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    that scancom job looks like just the thing I need. I think I have one of their switches for svideo duties at the mo, and i'll be upgrading to component soon. 2 outputs is perfect for TV and projector.
    Anyone used one of those and can comment on its quality?
  8. rob27
    rob27
    Nov 2, 2004
    162
    +9
    I just used a Composite switcher
