Thinking about Freesat, what will I need?
s_inman
I am going to purchase 2 freesat boxes, 1 normal box and 1 HD box. I have a sky dish on my house but the lnb has only 1 output. How easy is it to change the LNB? Also where is best to buy the LNB and what king of cable will I need?
Thanks in advance.
Stuart.
CanaryPhil
Stuart, it is very easy to change the LNB, but make sure you get one to fit a sky type dish, as the mounting is different to the normal european ones. They can be ordered from EBay or I use www.satcure.com. They can also supply the RG6 cable and connectors.
Good Luck
Phil.
Simon Kemp
Dear Stuart,
At the risk of telling you something that you already know, and hence causing annoyance, I assume you are aware that a High Definition Freesat satellite receiver box (priced at around £140 - £150) is also a Standard Definition receiver?
This must be so because there are currently only 2 1/2 High Definition channels on Freesat - counting Luxe TV as a full channel and ITV HD as half a channel, which might be a trifle generous.
There is no point paying another £40 - £50 for an SD receiver once you've bought the HD variety.
Hope you don't mind me making this point.
Best regards.
Yours sincerely,
Simon Kemp
S. KEMP
