Think this be any good for Sharp for mounting on wall
Discussion in 'Home Cinema Buying & Building' started by Rookies, Oct 29, 2005.
  1. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    I have a sharp 26" in LCD as you all prob know but want to mount it on the wall. But the wall it going on is a plasterboard wall with wood studs. I believe the wood Studs are 2 " wide from what I can figure out with the device I borrowed,
    DO you think this bracket be any good? 2nd one down
    http://www.standanddeliver.com/acatalog/brackets.html
  2. Rookies
    Rookies
    Jan 4, 2003
    5,681
    +542
    Any help here please guys. I have seen many bracket saying 22" to 24" LCD max weight of 15KG. but my Sharp is 26" but weight is 12KG without stand according to sharp so surely these bracket should be ok am I right or wrong?
