Thin white vertical lines on screen, is this normal?
Discussion in 'Plasma TVs Forum' started by yan, Sep 17, 2004.
  1. yan
    yan
    I have thin white vertical lines that appear on my pio 504HDE regardless of the channel, usually they are easier to pick up on a lighter backgrounds. They are evenly spaced across the screen, but can only be seen from close up say about 1-2 metres away. Has anyone experienced this, am I being too fussy as they cant be seen from my viewing position. I recently had a new arial for terrestrial channels placed on the roof near the dish could this be causing interference.
