Thin Speakers
Discussion in 'Home Cinema Speakers' started by nheather, Apr 24, 2005.
  1. nheather
    nheather
    Oct 6, 2004
    15,402
    Horsham, West Sussex
    +4,552
    I thought I had my prospective speaker system sorted but at the weekend the cheif of interior design redid the lounge plans and whilst my initial choice (MS Premiere Plus) might still work I suspect some thin wall mounts would look better.
    The reason is that the plasma will now be above the fire so will be much higher (possibly tilted) then originally thought.
    I've seen pictures of such installations and the ones with long thin wall mounts look better to me.
    So these are my two ideas
    Canton: CD50 (centre and fronts), CD10 (rears) and AS22 (not sure whether front or down firing)
    Infinity Oreus (seen a few recommendations but can't find much info on them)
    (i) Are these good options
    (ii) Is the Canton selection I've made a good set or should I consider other components. I did consider 360s as the fronts but am concerned that the drivers wouldn't match the CD50 centre and I can't find whether you can buy them singlely.
    (iii) How would my Canton selection compare with the Oreus
    Thanks,
    Nigel
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    I have heard both (was a big fan of the Oreus) but the cantons do sound better IMO of course
