Thin speaker cable
Discussion in 'Home Cinema Buying & Building' started by Trancerii, Jun 13, 2015.
  1. Trancerii
    Trancerii
    Jan 10, 2004
    360
    28
    +47
    Hi guys,
    Quick one really. I need some speaker cable for some Monitor Audio BXFX rear surround speakers I just bought. It needs to be thin to go under the carpet to be routed to the front receiver.
    Is there a particular one you guys go for, for your rears? Need about 8 meters and not too expensive.
    Cheers guys.
  2. shortyav
    shortyav
    Mar 17, 2010
    1,135
    Cambridge
    +137
    Installers will generally use 16/2 installation cable unless for higher end install this is around 5-6mm dia depending. QED micro is also very popular and thin. iOS did a flat cable. Google would probably throw up a few options.
  3. Dolus
    Dolus
    Apr 26, 2005
    600
    46
    Gosport
    +186
    Being in the same position as you two years ago I went for this thin cable for the rears. It works jut fine though it is a little stiff so might need a blow with a hair dryer for tight corners.
    £1.75 metre
    https://www.audiovisualonline.co.uk...covert-ultra-silver-plated-ofc-speaker-cable/
    Non silver plated £1.50 metre
    https://www.audiovisualonline.co.uk/product/2885/fisual-covert-high-purity-miniature-speaker-cable/
    They also do this flat one for under carpets though I have no experience of using it. £1.20 Metre
    https://www.audiovisualonline.co.uk...nstall-series-low-profile-flat-speaker-cable/
