flemingcool
Established Member
I'm after some advice.
I'm mounting my TV on the wall. I'd like to channel the wires into the wall and allow myself the option of upgrading/adding equipment over the coming years.
I was planning on using some big fat conduit with a couple of double brush plates for access. However after starting to channel the plaster I've found out the plaster is only 20mm thick, then you hit brick. This obviously isn't deep enough for what I require. So I'm after some help/advice about my alternatives.
1. False wall - how easy/hard is this? I have great big 70's coving at the top, and I think this complicates this. I don't want to remove the coving really.
2. Bore into the garage in two places and run cables down my garage wall. Only problem is garage isn't insulated and bore bits cost about £80
3. conduit less than 20mm thick.
Anyone got any advice about the best way to overcome this?
Thanks.
Thanks.
