Thin, flexible, High Speed HDMI cables
AidenL
Hi all.
Just wondering what you would recommend as a skinny , flexible HDMI cable, one which ideally would handle 18GBs over 8m approx?
I bought some Amazon basics, but they are quite thick and inflexible.
Thanks in advance.
AidenL
Anyone have any pointers on this?
AidenL
Thanks Joe. Do you have them on your site?
Also, for 'basic' 10gig 4K , any standard skinnier ones, as in non fibre?
Joe Fernand
AVForums Sponsor
Site is currently down for a clean up.
Drop John a note ([email protected]) and he can confirm pricing.
Have only used the slim wire cables up to 5m and even then only a couple of times.
Have you considered adding a short flexible 'tail' at each one of the installed cable - takes the strain off of the Input/Output sockets.
Joe
AidenL
Joe
Thanks!
What would the tail be?
Joe Fernand
AVForums Sponsor
'What would the tail be?' - a short HDMI (F) to HDMI (M) using some of the very flexible cable stock.
Joe
Similar threads
