"Thin" 3.5mm to RCA Connectors
Discussion in 'Computer Components' started by Klopek, Aug 26, 2013.
  1. Klopek
    Klopek
    Nov 5, 2005
    345
    +46
    I have just purchased an Xonar DX but the 3.5mm ports are very tightly packed together. I need to connect four in a row for 7.1 output but none of my current cables fit. The plastic base is too fat to fit them side-by-side.
    Here is the backplate of the sound card.
    I've had a jump on eBay but can't really tell from the pictures which cables are going to fit.
    Has anybody else run into this problem recently? Anybody know where I can find cables that are sure to fit? I'm either after 3.5mm jack to RCA cables or even just a really short 3.5mm male to female jack cable so that I can use some of my existing cables.
    Any help would be greatly appreciated.
  2. BoUnCiNBeN
    BoUnCiNBeN
    Mar 14, 2008
    681
    brierley hill
    +76
    Try the home cinema section . The guys really know their stuff and and a couple of em may have the facilities to make some custom leads for you.
  3. Klopek
    Klopek
    Nov 5, 2005
    345
    +46
    Thanks to next010 and BoUnCiNBeN for the posts.
    The solution was seemingly quite simple - I needed the word 'slim' accompanying my searches. I bought 4 'slim' 3.5mm jack male to female leads.
    Thanks again.
