Thick speaker cable
Discussion in 'Cables & Switches' started by Marvt74, Sep 24, 2005.
  1. Marvt74
    Marvt74
    Feb 13, 2005
    618
    Manchester
    +20
    I've just bought some QED SA biwire cable and with 2 strands together i'm having trouble connecting the amp, its in to an extent but theres some slight crackling when its on a quiet note.
    How do others manage or is it just a case of really compressing the 2 together?
  2. Knightshade
    Knightshade
    Aug 6, 2004
    1,971
    +43
    You could try using either banana plugs or spade connectors. Save having to try and stuff all the cable in.
