Theydon's Perpetual Build (AKA Triggers Broom) & LAN Sessions
Discussion in 'PC Gaming & Rigs' started by Theydon Bois, May 10, 2011.
  1. Stockholm
    Stockholm
    Sep 15, 2004
    4,255
    Glasgow
    +1,883
    Theydon, isn't their a number of software packages out there than can retrieve data from broken HDDs?
    Edit - I guess most of them require the HDD to actually work but have corrupted data/sectors or something.
    Found this...
    http://www.popularmechanics.com/technology/how-to/tips/4294038
    With mechanical failures it seems that firms charge crazy amounts to recover your data. Why?
    This seems like a good website and company. Lots of handy info on the different types of failures and how to recover from them. They also offer retrieval services.
    http://www.dataclinic.co.uk/hard-disk-failures.htm
  2. Hillskill
    Hillskill
    Moderator/Games Reviewer
    Mar 10, 2005
    22,439
    Somewhere being wrong but staying strong
    +5,409
    I RMA'd a Samsung the other day with Seagate and the whole process took no more then 7days. Really impressed with their service.
  3. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    Yep, I downloaded the Seagate one (linked from Samsung) but the search does not complete while the harddrive is plugged in, and will only resolve if the hard drive is turned off.
    Also, Disk Management refuses to show any data while the drive is plugged in, and the whole PC slows down and the click click click is bloody annoying. :D
    I will try a Hiren via USB with the hard drive in its caddie and see if there disk tools can spot it though.
  4. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,798
    127.0.0.1
    +7,577
    AFAIK the tools to do it are very expensive and it can be quite a long and tedious task. I would imagine that there is also the fact that for important things people will pay a fair bit.
    That's good to hear though I've no idea if my [in warranty] F3 will count as faulty.
  5. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    Nah, such is life, as I mention, this is my first dead drive (related to me specifically and my data) so I think I have been ahead of the program so far. The only trouble is as drives become bigger and bigger, you can only potentially lose more and more data from it.
    I will grab another Sammy next month - £95 for an F4 2TB at Aria, maybe they will drop a little by then. I think I have had 9 or 10 Sammy Spinpoints since my first purchase, a 250Gb version, so I dont think this will put my off buying them in the future.
  6. Stockholm
    Stockholm
    Sep 15, 2004
    4,255
    Glasgow
    +1,883
    Thanks SniperAsh. Got a lot of good info from you today! :smashin:
    Dataclinic seem to have a few good testimonials out there from satisfied customers, but it is hard to find out how much they charge. I'm guessing it will be more than £500 :(
  7. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    Now spending time collating all the data I have found on numerous USB hard drives and my temp folder. Oh the joys of tidying and consolidating data on a PC.
  8. Grangey.
    Grangey.
    Apr 24, 2006
    5,756
    Oxfordshire
    +873
    Wack it in a sealed sandwhich bag and wack it in the freezer overnight, not a permanent fix but if it works it may get the disc to spin up fully again so you can transfer the remaining stuff you Havnt backed up! It's worth a shot as its worked for me before!
  9. Deadringers
    Deadringers
    Jul 14, 2008
    9,817
    Herts
    +1,800
    What's the thinking behind doing that mate?
    I know for some equipment like xboxes you allow them to heat up and "re-solder" their dry joints on the pcb and therefore making them work again.
    But what's the theory behind cooling hard drives down?
  10. Grangey.
    Grangey.
    Apr 24, 2006
    5,756
    Oxfordshire
    +873
    I can't actually remember tbh but I'm sure theres stuff on the net about it. I don't think I ever really got why but I tried it and it worked- on a couple of drives Aswell. I guess it depends what the fault is but I had similar issues- the drive just sounding like it couldn't spin to any real rpm and just clicking away (almost like an engine just turning over).
    Abit of time in the freezer and it spun up to full speed a couple of times (I shut down not expecting it to fire again but did) before dieing again
    Edit some links
    http://www.datarecoverypros.com/hard-drive-recovery-freeze.html
    http://m.lifehacker.com/5515337/save-a-failed-hard-drive-in-your-freezer-redux
  11. Stockholm
    Stockholm
    Sep 15, 2004
    4,255
    Glasgow
    +1,883
    That's brought back some memories Grangey. I had a HDD that was mechanically failing and was clicking whenever I tried to boot it up. I put it in a number of ziploc bags and put it in the freezer for 24 hours. Didn't let it come back to room temp before trying it out - and it worked! Was able to get some data off of it before shutting it down for good.
    It's definitely worth trying that Theydon.
    Save a Failed Hard Drive in Your Freezer, Redux
    Ha, the pic of the HDD in that article is identical to the one that failed on me! Must be common to the brand.
    Edit - Oops! Just seen your link to the same article Grangey. Nvm.
    Edit 2 - What is up with the suggestions on the first website in your link - drop the HDD on the ground or hit it to fix it! :eek:
  12. Grangey.
    Grangey.
    Apr 24, 2006
    5,756
    Oxfordshire
    +873
    Nope- don't let it go back to room temp, connect that badboy up ASAP! :)
  13. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    Nothing to lose, so in it goes. I will give it a good 16hrs or so, and check it tomorrow when home from work. :smashin:
  14. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,798
    127.0.0.1
    +7,577
    Let us know what happens :thumbsup:
  15. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    Strangely my Sammy that failed was also a 1TB F3. Same 'tick, tick' that mine died of too.
  16. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,798
    127.0.0.1
    +7,577
    I sense a pattern here :(
    I may see if I can get a recording of what mine does and see if I can contact anyone to find out if it's RMA-able.
  17. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    Data backed up first before you take your pc to the recording studio :)
  18. Kirki
    Kirki
    Jul 15, 2009
    1,139
    Liverpool
    +244
    Oh bugger... (looks at sig) :( :rolleyes:
  19. Grangey.
    Grangey.
    Apr 24, 2006
    5,756
    Oxfordshire
    +873
    Ive also got the Sammy 1TB and have seen a friends one fail- however Im walking on the tight side at the moment as for me I COULD double my capacity and have my stuff mirrored, but at the same time the cost of that doesnt seem very effective (perticularly at the moment) not to mention that any drive can fail so theres nothing to stop my backup drive failing at the same time lol.
  20. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    Over the last 7? years I have bought the following Samsung drives for my use in either Main PC or my HTPC:
    • Spinpoint 250
    • Spinpoint 320
    • Spinpoint 500 (or a 400, cant remember)
    • Spintpoint 750
    • F1 1Tb x 2
    • F3 1Tb x 2
    • F4 2Tb x 1
    The 750 onwards are still in use, and the 500 may be in a PC I sold off ages ago. One of the F1's is the one I have a problem with.
  21. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    So, what happened to the Bois drive of goodies after 16 hours in the fridge?
    • No clicking, but Windows would not see the drive at all.
    • I waited a few minutes and tried again, and windows say it, but wanted to format it.
    • There was no clicking at all.
    • Various Hiren's recovery programs could see the drive and a whole heap of files in that soul destroying long list of 8.3 naming and random hexadecimal characters.
    • Booted into Hirens, and after trying a few programs, Disk Genius actually not only could see the drive, but put it back into order :D
    • Disk Genius says it has saved the partition, but doesnt :(
    • Boot back into Windows and windows still wants to format it. No click though
    • Ran DG in Windows, and found that I could export files from within the partition.
    • Started exporting files, thankfully this drive had less files on it that I need compared to the backup I had from last year.
    • Some files are corrupted (CRC errors) but things are looking ok
    • No clicking still, some 2 hours after I got it out the fridge
    Phew. And I dont mention the bit where I got up to grab a coffee and kicked the hard drive across the floor. Oh wait.....:blush:
  22. Grangey.
    Grangey.
    Apr 24, 2006
    5,756
    Oxfordshire
    +873
    strange windows wanted to format it...
    but still
    cant beat the freezer trick ;) youre welcome lol
    Hope you managed to get everything you need off it :)
  23. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    Looks like I cancelled a recovery option earlier, thinking I may have been doing the wrong drive (never used Disk Genius before).
    After stopping panicking, I started the process again and am currently recovering more files now, and looks like its half way through at the hour mark, finding 24k files.
    Weird day, as today I managed to get my mates hard drive with his Time Machine backups to work - the portable drive casing was broken (and physical connection between drive and usb port), but not the drive itself, so I could restore a time machine backup of his User folder and get all his kids pics back :smashin:
  24. Grangey.
    Grangey.
    Apr 24, 2006
    5,756
    Oxfordshire
    +873
    Productive day then! :thumbsup:
  25. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    Three and a half hours later, and 40k+ files recovered and still within the file structure (although only within Disk Genius).
    Setting up some files to copy now - I lost all my Skyrim mods as well and all the mods and save games that I backup, so glad they are accessible.
  26. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,798
    127.0.0.1
    +7,577
    Considering you could have ended up with nothing that's pretty impressive
  27. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    I have over 10TB of data on multiple hdds, there's simply no way I can back all that up...
  28. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    36,755
    10
    13
    CyberSpace
    +11,176
    Of course there is ;)
  29. Theydon Bois
    Theydon Bois
    Jun 26, 2007
    16,095
    Sauf Lunden
    +7,178
    Yep, it does take ages though - Disk Genius can take more than an hour to even start the copy process, which itself not quick. I am not complaining, but it does seem like I was sitting as usual watching a little blue bar do nothing at all until gone 1am last night :D
    I will continue the process toinight, but its one of those things where you think "oh noes!" and then find that although some things are missing, you have nearly everything so its not quite so bad. Annoying, but not rage inducing.
    I think that my old saves are all gone though (not that I need them really and its possible that nothing has changed from August 2011 backup) and all the mods I had for Games are all gone as well - I will just have to check my Skyrim NMM to double check what I had - there only backups after all as the mods are already installed.
    Until Hard drives grow on bushes and trees, no, not really :D
  30. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    Im a little disappointed at how slow the HDD industry is moving. By now we should have 5TB or even 10TB single HDDs. (is a petabyte disk nothing more than a dream?)
    I should be able to get all my stuff onto 1 HDD instead of of so many 1TB/2TB disks.
    Especially with us all "backing up" our Blu Rays! :D
