Theta amps.
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by uncle_git, Oct 6, 2004.
  1. uncle_git
    uncle_git
    Anyone got any feedback on the Theta Dreadnought II ?
    I'm pondering pairing one with an arcam AV8, B&W 803's front 805's rear and the matched center.
    Other Power amp options are Arcam P7 and the Primare 5 channel unit.
    I'd probably get 3 single channel cards and 2 stereo cards for the surrounds planning for a later 7.1 upgrade.
  2. bamber
    bamber
    Dec 2, 2002
    216
    16
    Hi uncle_git
    I demoed the Theta Dreadnought II a while back and thought it was pretty good driving B&W 802's. Make sure you demo all the other forum favourites Bryston/Krell/Parasound.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,961
    +1,671
    Pretty much as gazza has said....excellent amp,beautifully built,bags of power and very good clear sound,and pretty tolerant of difficult loads like the B&W 805.
    You could have a look at the following link for a review of the next model down ( http://www.stereophile.com/amplificationreviews/625/ ),which may give you some idea of what it's like.
    Again,to go with waht's already been said,other choices should include those mentioned,and a number of us(myself included) have found Krell to be an excellent choice in terms of power delivery and control....I didnt buy my Krells to go with the B&Ws,but found them to be an excellent match.
