These seem nice...
A
AwesomePawsome
I'm new to the forums, and I could use some help.
First off, do I need 480i inputs on a TV? In what way would they be needed?
Secondly, how will the following TV's be for gaming? It doesn't mention the response time, which I know is important if I don't want any lag while playing video games. How can I find out the response time?
1) Samsung 30 in. HDTV with Built-in HD Tuner, SlimFit™
2) Toshiba 34 in. HDTV Monitor, FST PURE® Flatscreen
3)Samsung 30" Widescreen Flat-Tube HDTV
4)Samsung DynaFlat 26" Widescreen Flat-Tube HDTV
Which will be best for playing Xbox 360 on? Can I get anything better for under $1,000.00?
Stephen Neal
Sorry to disappoint - but this forum is mainly frequented by us Brits. Suspect you are asking about HDTVs for the US - where 480i is the main standard definition format (i.e. what your VCR and OTA analogue, and SD cable will be delivered in)
In the UK we use 576i instead...
Yes - you do need it. It will be almost impossible to find a US TV that doesn't support 480i.
Suggest you go to www.avsforum.com which is more US-relevant.
Trending threads
Trending threads
