theoretical question.
Discussion in 'Home Cinema Speakers' started by Faze, Oct 15, 2001.
  1. Faze
    Faze
    Just doing some research on speaker enclosure designs and wondered what you guys think.
    How do you think cabinet construction materials affect the sound eg MDF against Birch ply or composites.
    how much does the enclosure shape affect the speaker sound eg Cube vs Rectangle vs pyramid vs sphere vs cylinder etc
    which enclosure design offers the best freq response eg vented vs sealed vs horn.
    plus anything else you might think is relavant.
    thanks in advance for any comments!
    Faze
  2. Confucius
    Confucius
    Feb 1, 2001
    2,151
    Oxford
    +132
    All the things you mention will affect the noise a speaker emits.
    One thing you did leave out is their position relative to eachother and other objects.
    My guess is one could write a very weighty tome on speaker design and not reach any 'ideal' conclusion.....
  3. Faze
    Faze
    I purposely left positioning as that is one thing that is easy to change, however if you have just brought yourself a speaker setup consisting of cylindrical vented cabinets in birch ply, it's not something you are going to change to easily if you don't like the sound.........
    perhaps I should rephrase slightly.
    what design features would you like to see in a speaker enclosure given free reign in terms of cost and manufacture (eg pyramid/cylinder/sphere/horn/whatever shapes were easily possible) and for what reason?
    Faze
  4. GaryG
    GaryG
    Ideally they shouldn't affect the sound at all, you want the sound to come from the speaker, not the cabinet. Unfortunately, the cabinet will add resonance it's just a question of minimising it as much as possible.
    Take a look here at the results of different enclosure shapes. It will give you some insights into why the B&W Nautilus range is shaped the way it is.
    http://members.aol.com/kmetaverso/graphs.htm
    Depends on what tradeoffs you're prepared to live with! For example a sealed cabinet will have a better group delay response than a vented cabinet which will give a 'tighter' sound, however, a vented cabinet will have a lower frequency response than a sealed cabinet due to the output from the port at it's resonance frequency.
    There are a number of good books on the subject, take a look at the bookshop section of Wilmslow Audio.
    https://secure.wilmslow-audio.co.uk/acatalog/Wilmslow_Audio_Books_on_Loudspeakers_9.html
  5. Faze
    Faze
    So an ideal speaker enclosure - would be one that is constructed in a non-resonant material in a spherical shape?
    the only decision left to make is weather to go sealed or vented - what about horn loaded? anyone have any expirience of that sort of enclosure?
    Faze
  6. Lowrider
    Lowrider
    There is no design ideal for everyone, I can show you box shaped speakers that sound much better then cilindrical or whatever...
    Why dont you go and audition speakers until you find one you really like ? And then it might not suit your listening room :mad:
