Themscene H56A
Discussion in 'Projectors, Screens & Video Processors' started by Scotlandgadgets, Oct 7, 2004.
  1. Scotlandgadgets
    Scotlandgadgets
    I was just enquiring about a themscene H56 A on a website and even though the site should avaliable stock they informed me that they do not have any left in stock and that the unit is about ( has been ) to be discontinued and they were waiting for info on the H57 model.
    Does anyone know anything about this.
    Thx
    Sham as i had set my sights on the H56A.
    Thing i will see if they can try and get one in.
  2. dazca1
    dazca1
    Nov 2, 2003
    556
    +8
    H57 is supposed to be due next month.
    Will be a lot better than h56 I think, looking at the specs.
    Do a search for h57 on google and have a read for yourself.
  3. Scotlandgadgets
    Scotlandgadgets
    Thx will do any idea of cost.
  4. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    We are taking orders now, we have priced it at £1800, :clap: spec.
    Native Resolution 1024 x 576
    Contrast Ratio 3500:1 (SHOULD BE RELEASED WITH 4000:1)
    Brightness 900 Lumens
    Lamp Type 250 watt UHP
    Lamp Life 4000 hours
    Video Compatibility PAL\SECAM 576i/576p
    NTSC 480i/480p
    HD 720p/1080i
    Uniformity 90%
    Inputs Digital Video HDCP DVI
    SCART RGB - VGA (via SCART RGB adaptor)
    S-video (4 pin MINI DIN)
    Composite RCA x 1
    RS232 (3 Pin MINI DIN)
    Noise Level 23dB
    OSD Languages English, German, Italian, French,
    Spanish, Norwegian and Russian
    Dimensions (W x H x D) 340 x 127 x 260 cm
    Projection Lens f=28.3 - 38.2mm, F/2.4,1.35
    Power Supply Power Consumption:
    320W in operation
    <20W in standbyControl Infra Red control
  5. Scotlandgadgets
    Scotlandgadgets
    Hi does anyone know were in newcastle i might be able to see the H57.
    As i am from the north of scotland but down in newcastle in 2 weeks would like to veiw before i buy.
    Thx.
