Themscene H30 - making the picture smaller?
Discussion in 'Projectors, Screens & Video Processors' started by key130, Jun 15, 2004.
  1. key130
    key130
    Mar 21, 2004
    33
    Manama
    Just took delivery of my H30 yesterday :D
    Connected it to my laptop to see how the picture looks. Fantastic!
    My question - how do I make the picture smaller? The projector is to be mounted on the back wall and beam the picture on the opposite wall. However, the image is too big! I reduced the manual zoom to the minimum.
    Is there a way to make the picture smaller? :confused:
    Thanks.
    Al.
  2. D J Fryer
    D J Fryer
    Jul 14, 2000
    758
    High Wycombe, Bucks
    +18
    Try checking out the throw distance calculator for your model of projector on www.projectorcentral.com - this will tell you what minimum distance is required from the screen for any given size of screen - it may be that the H30 cannot do the size of image you require with the distance you have at your disposal.
    EDIT - here is the link http://www.projectorcentral.com/projection-calculator.cfm Select Optoma and H30 and away you go! Its not always 100% accurate but it should give you a good idea
  3. LongBow
    LongBow
    Have you tried setting the screen size to 16:9 in the menu. That way you could have a 4:3 image in a 16:9 frame. It will give you black bars on the left and right though.
    Just a thought.
    LongBow
  4. key130
    key130
    Mar 21, 2004
    33
    Manama
    I looked at the calculator before. I always find it easier to try things out. Having re-checked the calculator, it doesn't seem it will go any smaller.
    I also tried changing the viewing format options to 16:9, which is my preferred viewing format. The picture is still massive!!
    I don't want to mount the projector on the ceiling to bring it any closer to the screen.
    Right, have to find a large widescreen projection screen at a reasonable price - any suggestions?!
    Thanks,
    Al.
