themescene h30a - no picture - confirm connections??
Discussion in 'Projectors, Screens & Video Processors' started by bikerjodie, Jun 25, 2005.
  1. bikerjodie
    bikerjodie
    Jun 13, 2005
    319
    Glasgow
    +20
    :lease:
    I am at my wits end. I cannot get a picture on my screen no matter what i try.
    I've tried to bypass my b-tech 945 and inserted the vga cable from my pj directly to my dvd player (should i get a picture then?) i got nowhere.
    My vga cable has 13 pins the receiving female locators have 15 holes (is this right?)
    Can i have purchased a faulty h30a or vdc-vga cable?
    Does anyone know the settings for the h30a connected through the bt945?
    Or, how i check that the cable and projector are working properly?
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    The VGA scart adaptor is for RGB video signals only IIRC. This means you need a DVD player which can do RGB out of it's scart socket (most do) and to actually have that setup in the setup menu of the player. Same for Sky TV - need to go into services menu, picture settings, and select 16:9 and RGB video output. Ensure you are using fully wired cables between sources and swticher (scart leads with only a handful of pins connected will not work for RGB video).
    HTH
