Themes
Discussion in 'Xbox Forums' started by weaponx_uk2003, Aug 5, 2006.
  1. weaponx_uk2003
    weaponx_uk2003
    Jan 17, 2005
    1,724
    +98
    Can you only download themes on LIVE or is there any way of downloading them on PC and putting them on 360?
  2. Deleted member 92943
    As far as i'm aware the only other way is by getting some demo discs which have a new crap ones on. But when Microsoft launch Vista i hear that you will be completely able to customise your dashboard with new themes on the computer
  3. weaponx_uk2003
    weaponx_uk2003
    Jan 17, 2005
    1,724
    +98
    bummer
    thats i bit expensive fr me just so i can chnage a theme...lol
    and one problem is the amount of vistas theres gonna be. hope i pick the right one ...:p
  4. NackNack
    NackNack
    Aug 28, 2005
    3,562
    68
    Northampton
    +97
    There have been loads of different versions of Windows before and no one's been confused, you'll be fine.
    There are plenty of themes on the hard drive already, no chance of getting on Live either? Plenty of free ones!
