Theatretek question
Discussion in 'Desktop & Laptop Computers Forum' started by onewingedangel, Jan 24, 2005.
  1. onewingedangel
    onewingedangel
    Sep 9, 2003
    436
    +29
    When they release new patchs or builds, do you have to pay to upgrade? eg. 2.1 should be out soon, and if I got 2.06 now at £40 or whatever it is, would I not be able to upgrade to 2.1 without paying extra.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Past experience says not, 1.5 was a free update to 1.2 and I think it inconceivable Andrew would charge for 2.1, not least because of the ropey start 2.0 had.
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    Yeah I doubt there will be any charge until a version 3 appears .
  4. onewingedangel
    onewingedangel
    Sep 9, 2003
    436
    +29
    Just as an aside, do you think theatretek is worth getting, over say the nvidia dvd decoder, and using the free version of zoomplayer? £10 vs £40 is a big jump.
  5. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I suspect quality wise they will be somewhat similar but Theatertek is more user friendly at least initially.
  6. dan1979
    dan1979
    Sep 16, 2004
    3,525
    83
    +201
    Isn't the Nvidia decoder £12 + another £12 for Zoom Player
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Yes you're right, the free version of ZP doesn't support DVD playback, you need the paid-for 'Pro' version for that.
  8. onewingedangel
    onewingedangel
    Sep 9, 2003
    436
    +29
    the nvidia decoder is about £12, zoomplayer comes in various forms, a free one, a $20 pro, and $30 pro with wmv cp support. I thought the free version may be good enough for dvd playback, but getting the pro + nvidia decoder is still quite a bit cheaper than getting theatretek. Whether its worth getting TT for convenience sake though...
  9. dan1979
    dan1979
    Sep 16, 2004
    3,525
    83
    +201
    Is the Nvidia decoder worth £12 though compared to the competition?
    I might try the 30 day download to find out.
    Zoom player is pretty buggy but does the job most of the time.
  10. Zig
    Zig
    I tried the Zoomplayer pro and the nvidia codecs both on trial. I wanted to use ffdshow as well but struggled to get them working well after many hours of trying. I bought TT and it was very simple to configure and runs fine with ffdshow with no hassle.
    Much less stress to go TT, it was worth it for this alone for me.
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    One problem that I've seen mentioned is that until you activate TT (and hence the codecs) they're not intended to be used outside of TT and thus nVidia make it hard to do so.
    ZP is way better for the inveterate twiddler .. an ideal tool to use FFDSHOW with, with so many options available in both there's no excuse whatsoever for having to actually WATCH a movie. :D
