Theatertek
Discussion in 'Desktop & Laptop Computers Forum' started by DustySox, Dec 13, 2004.
  1. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    Hi everyone,
    Couple of questions-
    I have used DVD shrink, and running "shrunk/modified" film through Theatertek, causes the film not to run and locks up Theatertek (vers 1.5**). Any thoughts on this?
    How would I go about loading, for example Pearl & Dean ad everytime Theatertek boots up?
    Another question, does Windows media player support Dolby Digital? And can it play box standard DVD's?
    Kind regards
    Darren
  2. HarshKarma
    HarshKarma
    Jun 28, 2004
    82
    9
    Ashford, Kent
    WMP can't play DVD's, you need to buy an addon decoder.
  3. HarshKarma
    HarshKarma
    Jun 28, 2004
    82
    9
    Ashford, Kent
    Forgot to say...
    The PowerDVD addon only does 2 channel (or used to). Looks like the nvidia and intervideo both support DD (in addition to downmixing to 2 channel) but check before you buy.
  4. Embarker
    Embarker
    Apr 19, 2004
    1,676
    Garden of England
    +70
    Theatertek 2 supports WMV playback for sure. However, with TT2 and PowerDVD 5 or 6 you need to "BUY" the extra audio codecs for anything more that 2 channel analogue.
    I rip loads of films with Shrink 3.2 and use TT and have no such problems.
    If you "dump" all the extras and the audio tracks you do not need and even the end of film credits you'll save a couple of gb's each time. Just the film in it's uncompressed glory.
    I'm still working on random trailers though..........
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Darren,
    Like Embarker, I've run 'shrunk' DVDs through TT 1.5 and 2.0 for a long time without any problems, I think there's something specific to your system or maybe the version of DVD Shrink or options you're using that are unusual.
    What version of Shrink are you using?
    For sound, are you wanting the PC to do the decoding or simply send digital audio to a receiver? SPD/IF Pass-Through should work on any DVD player I would think.
  6. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    Thanks for your replys. I am using shrink 3.2. I managed to get Theatertek to play a "shrunk" film, yippee! Then a few days later it locked up, I'll re look at the resulting video_TS file again. Strange really as it plays in Power DVD ok.
    Darren
