Theatertek website problems?
Discussion in 'Desktop & Laptop Computers Forum' started by esta56, Nov 28, 2003.
  1. esta56
    esta56
    Jun 18, 2003
    195
    Grays, Essex
    +8
    Is it just my internet connection (Blueyonder - Cable Broadband) or does anyone find access to Theatertek's website intermittent?
    I've been trying to get the site up for the last hour but to no avail. I've noticed this before, some days I can get access and then other days, no joy.:(
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Have just tried it and it works fine for me via my BT ADSL line.
    Cheers, Lee
  3. helipilot
    helipilot
    Sep 20, 2001
    319
    Hamilton
    +19
    For some reason blueyonder can be a complete pain when trying to access the Theatertek web site.
    In internet explorer go to tools......internet options ........connections .......lan settings.
    tick the box to use a proxy server and enter the following :-
    address :- webcache.blueyonder.co.uk
    port :- 8080
    That should get you up and running !
  4. esta56
    esta56
    Jun 18, 2003
    195
    Grays, Essex
    +8
    :clap: Yey! It worked.
    Thanks Helipilot. I have no idea what you got me to do though. Could you explain why I couldn't get in before and now I can?
  5. helipilot
    helipilot
    Sep 20, 2001
    319
    Hamilton
    +19
    Nope! not 100 per cent.
    When you use a proxy server to point to a web cache the following situation arises :-
    When you try to access a web page the cache is checked to see if the page you have requested has been requested before. If it has, it is transfered from the cache to you. If it has not been requested before the cache is bypassed and the page requested is downloaded direct from the site you requested. This means that if you want to download a page from a slow server it can be retrieved quickly from the cache (a very fast server). Webcache is basically a big buffer that stores frequently requested web pages. Its supposed make your browsing much faster although sometimes it does not.
    I can only assume that the theatertek web site is hosted on a lousy server or that its often offline.
    hope that helps, maybe someone else has a better explanation ?
