TheaterTek Web Site
Discussion in 'Desktop & Laptop Computers Forum' started by donmc, Dec 23, 2003.
  1. donmc
    donmc
    Is it just me or is has the TheaterTek Web site moved? I've tried several times to www.theatertek.com and i get timed out?
    I'm just in the process of rebuilding my HTPC and could do with downloading the latest version.
    Don
  2. The Nightfly
    The Nightfly
    Aug 31, 2002
    801
    The New Frontier
    +23
  3. Messiah
    Messiah
    Apr 22, 2002
    7,530
    +339
    Doesn't work for me either :( (neither of the above links work)
  4. donmc
    donmc
    How very strange! I tried to log into their forums a month or two ago and got the same response and thought they'd gone out of business. Still can't get through. Can you check their IP address in case it's a name resolution problem. Mine comes up with theatertek.com [207.44.240.107]
    TIA
    Don
  5. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    Site has always been there and works fine.
    Ken
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    What ISP are you with? Many use web proxies and NTL for example are legendarily aweful at configuring these things. :mad:
    I can confirm their IP: 207.44.240.107
  7. donmc
    donmc
    Just down the road from you Ken!
    I use Telewest Broadband - Must say I've have relatively few problems to date!
    I'll investigate further - thanks for confirmation of the IP address.
    Don
  8. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Try doing a tracert to that IP, see if you've got a routing problem. If you can get through to their IP then you've pretty much proved a proxy problem I think.
  9. donmc
    donmc
    I get timeouts after about 13 hops. I'll log a call with my iSP and see what they say!
    Don
  10. donmc
    donmc
    ISP says slow ping times once we hit verio.net in the states and it's pretty much out of their control. Bummer!
    Are there any theatertek mirror sites anywhere?
    Don
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    No mirrors sadly that I know of .. you could try configuring a proxy in your browser so that the proxy's route rather than yours would be used.
  12. halephil
    halephil
    May 24, 2002
    61
    Hi, try the following Proxy:
    webcache.blueyonder.co.uk on port 3128
    It's a common problem for Telewest users with IP addresses beginning 82.36.x.x
    There are still routers worldwide that assume this is not a valid IP address range.
    Cheers, Phil
  13. donmc
    donmc
    Bingo! Thanks Phil and Kragorn, that nailed it.
    Phil - would you recommend leaving this proxy set up as standard?
    I'm suprised TW didn't fix this for me following my support call :rolleyes:
    Thanks again guys
    Don
  14. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    To be honest it's bad netiquette to use a proxy without asking :). Some publicise themselves as open to the public, others really are there for there own customers but will tolerate others.
    Which isn't say I haven't resorted to this in the past when NTL were playing silly beggars. ;)
  15. donmc
    donmc
    The silly thing is I am a Blueyonder customer and yet the support line didn't even offer this as an option :eek:
    Anyhoos....Thanks again!
    Don
