Theatertek Setup
sneaky
Hi all,
I have my HS20 Attached by DVI to a HTPC running Theatertek. Is it best that I run Theatertek on its own or should I be using ffdshow and reclock to get the optimal PQ.
OR some other stuff.
Chris
paublo
Try it out.... FFDShow and Reclock are really down to perception... value versus hassle...
I personally use Reclock to smooth our panning issues... Enable DXVA and see if you like it... only consider these third party developments if you see a problem.. FFDSHOW will process the image - playing with image quality. Reclock will adjust the timings of the digital sound stream to match refresh rates...
Enjoy
Paul.
Comer
I find FFDshow very good but AFAIK reclock will not work on the HS10/20's refresh rate of 56HRZ
Conor
sneaky
Thanks Guys,
I have noticed that reclock really slows down the startup of TT.
Are there any particular settings I need to use with ffdshow.
Chris
