Theatertek renderless mode
Discussion in 'Desktop & Laptop Computers Forum' started by automatt, Apr 14, 2005.
  1. automatt
    automatt
    Aug 23, 2004
    14
    3
    I'm using Theatertek 2, and have a 6600GT video card. I've just downloaded the xp sp2 patch to upgrade my sp1 system. So i'm now running windows xp sp2, so how do I enable vmr9 renderless mode? I have the option to select vmr9 but no mention of renderless. I'm sure I'm missing something really simple.
  2. Steve Bate
    Steve Bate
    Nov 10, 2002
    680
    Tarporley
    +11
    In the Video menu after selecting VMR7 or 9 go into advanced properties tab and there are two additional fields plus "use DXVA" select I think it's "full screen" and again I think (possibly optional) "YUV buffering?" and you'll be renderless. You can tell (apart from picture differences) by no traditional menu controls. You have to access by Ctrl C, via menus at the top of the page or by windowing TT.
    I think I'm right(ish)!!
    HTH
    Steve
  3. automatt
    automatt
    Aug 23, 2004
    14
    3
    Thanks Steve, that did the trick!
    Matt
