TheaterTek playback
(GTV)Chris
I was playing round with TheaterTek and a few movies(NTSC).
I noticed an amount of solarisation...especially on dissolves..get a sort of halo effect..
Worse than SKY.
I have a Radeon VE card and the latest patch from TheatreTek/.
What am I doing wrong? How do I get control of the image from the VE.
Any help would be great.
Chris
Mr.D
Have you tried running with the scoped overlay settings?
I use TT and a VE and get nada posterisation.
What display are you feeding?
(GTV)Chris
my setup is very new and I don't know what I'm doing :)
I dont know what the overlay thing means.....can you explain it please?
Feedung a AE100 and a monitor.
Do you work in movies? I work for a company called Granada TV making Drama and Comedy...
For any football fans reading this...I had no part in the ITV Digital cock up...
Who the hell would have used the most heavily compromised and hacked encryption service as the main platform...no wonder it went down the tubes :(
Chris
C
Couch Potato
Chris
To get to the Overlay tab go to Diplay properties then advanced and you should see the Overlay tab, you'll find the Scoped settings on the TT site
Steve
Mr.D
Yes I'm a film compositor. I work for a company called Cinesite Europe.
Take a look in your display settings as steve suggests. You might want to up the desktop colourspace to 32bit. Also you'll likely need powerstrip to get the accurate 1:1 pixel map for the ae100. ( covered in depth do a search)
The DVI output on the VE isn't great when used with the analogue RGB dongle so ensure you feed the raw RGB signal to the projector not the converted DVI one.
The overlay settigns will likely only become active when you actually run TT.
Check your recommended driver version also ( I run the 6025 with W2K)
(GTV)Chris
Thanx for the response.
I downloaded the new Radeon VE drivers and now when I play LOTR it hangs with a message saying TT.exe caused errors etc and needs to be restarted?????
Perhaps I should burn my HCPC as I am obviously a totally thick idiot......
I also couldnt find the overlay tab...I hate PC's :)
Chris
(GTV)Chris
OK...downloaded the 6025 drivers and installed them.
TT is OK now, but it hangs on the mountains at the beginning of LOTR???
I have heard of this before but don't know how to fix it.
Anyone got any ideas???
Chris
Mr.D
The LOTR hang is a known problem. Best solution is to start it from the chapter selct rather than the play movie option. Should be fine. (does exactly the same thing on my set-up).
Remember to use powerstrip for 1:1 pixel map loveliness.
Also take a look on the TT site for information on installing and uninstalling the radeon drivers correctly ( without leaving things hanging around from earlier versions)
(GTV)Chris
Cheers MR D.
I have downloaded Powerstrip but haven't set it up yet.
I have all the info for the AE100 settings from this forum....Is that what you mean when you say 1:1 pixel mapping?
Chris
Mr.D
yep or take a look on the AVS forums for a nice straight forward guide.
You want to set your display to 856x480 at 60Hz refresh fro the ae100. (powerstrip will allow you to do this)This will bypass any scaling on the projector and give you the best possible picture. Secondly take a look at mark rejohn's tracking and phase adjustment pattern .AVS forum again.
you may also need to set your monitor type to the sony GDM-W900 driver (this shoudl be available to you under most versions of windows)
Samsung QN800B 8K TV Review
