Theatertek << multi region ??
J
Jack Bowyer
I want to buy Theatertek but unsure what program to use to make it multi region ?? (1&2 i want..)
I 've just downloaded DVD Genie but can only see support for ones like WinDVD or PowerDVD etc
I hear Theatertek is one of the best for picture second by WinDVD maybe ???
Can someone help me...
Jack
paulS
I've always used DVD Genie & TheaterTek.
Never had a problem (after unlocking the DVD drive firmware).
Paul.
potfish
Not tried Theatertek but I use AnyDVD from Slysoft.com. Works for all the software I've tried and no need to hack the drive.
Donnacha
I don't use anything for TT - just my firmware hack for the drive itself. I thought TheaterTek was region independent anyway?
Peter Parker
When I tried it, it installed it's own region free software so you didn't have to find your own.
Unfortunately it did something to my existing Region Killer software which meant I couldn't watch RCE disks via PowerDVD.
As I couldn't see any difference between PDVD5 and TT, I uninstalled it and got a refund. I had to roll back to before the install date for my system to operate correctly with DVDs again though.
Gary.
Mr THX
Theater Tek is - its your DVD drive that isn't usually.
J
Jack Bowyer
Thanks for the come-back...
Went for DVD Region Killer in the end - works just fine.
Can anybody tell me what "AutoKiller" does from TheaterTek its in my startup reg ??
Jack
Peter Parker
I think that's it's own region killer software. It was probably that that caused my RCE problems with PDVD after it was installed.
Gary
Similar threads
Trending threads
