Theatertek + Lip sync problems
Discussion in 'Desktop & Laptop Computers Forum' started by Pantastic, Dec 16, 2003.
  1. Pantastic
    Pantastic
    I have recently installed TT and I am experiencing Lip sync problems when playing back DVD's on my HCPC. I am feeding my Yamaha amp via S/PDIF....
    When I restart TT the lip sync issue is resolved, but this is becoming annoying and I would like to sit down and watch a film....sometimes!
    I am running Win XP and had no issues before with PowerDVD.
    Can anyone shed any light on this issue?
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Are you using the recommended driver for the maudio?
    The so called October beta works fine for me.
  3. Donnacha
    Donnacha
    Jul 4, 2002
    8,029
    York
    +4,150
    Have you tried the forums on the TT website - they may be able to help. They're pretty responsive, or you may find someone else has the same problem.
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Sorry thought you had an maudio soundcard for some reason: yep go check out the forums for advice.
  5. Pantastic
    Pantastic
    Sorted now - downloaded the m audio driver from Oct 2002..no problems now!
    :clap:
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Oh you do have an maudio?
    Weird have to up the dose on my anti-psychic pills.
  7. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Having reread this thread, I think your psychic abilities are just fine
    BTW what colour knickers am I wearing?
    Conor
  8. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Brown.
    Course you'll deny it though.
  9. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    WOW!!! Well they sure are brown now
    Conor
  10. BOD
    BOD
    I have been having same lip-synch problem with TT and Maudio Revo. Used latest driver no difference.
    Change the latencies of your video card & audio card using powerstrip. That makes a big difference - also cleans up a lot of stutter.
  11. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Try the October beta driver : not the latest one.
    Alternatively use the microsoft hotfix with the latest. Details on the TT forums.
