TheaterTek DVD Review
Discussion in 'Desktop & Laptop Computers Forum' started by beyond, Nov 17, 2003.
  1. beyond
    beyond
  2. Gazzz
    Gazzz
    Does the TheaterTek player support playing DVD's from a hard drive, like PowerDVD does?
  3. beyond
    beyond
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Nice review .. shame it mentions the ability to use ffdshow but then doesn't show how, something that still bemuses me. :(
  5. beyond
    beyond
    their forums are a great are to find out how..
    I am writing a guide on using ffdshow as well.. it should be ready sometime in the upcoming weeks.
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I'll look forward to it. :D
  7. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    You really don't want to be using ffdshow with Theatertek, the software mpeg decoder isn't good enough.
  8. Gazzz
    Gazzz
    I finally decided to give TheaterTek a try... I can't see any way to play from a HDD?
  9. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    Dump it to a directory and use the /path command line switch to point to it.
  10. Mr THX
    Mr THX
    Nov 26, 2002
    1,295
    Barnsley
    +32
    Review is very interesting and screen shots do look very sharp, can it be found cheaper anywhere else though:confused:
  11. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    It's damned tedious, they don't provide a nice simple File|Open method :( ... you need to run it from a command-line or short-cut .. check this Hints and Tips page from their forums.
  12. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    The easiest way to use it is to have a shortcut setup for each movie.
  13. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Ahhha, that's assume you understand what you rae doing:mad:
    Have varoius "DVD's" on the hard drive, and would love to use theatretek instead of ht and miss vlc.
    I point a shortcut to the following, where am I going wrong guys:(
    "C:\Program Files\TheaterTek\TheaterTek DVD.exe" PATH F:\DVD's\T3
    Hopefully just some stupid computer code missing
  14. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    just followed the "how to get Theatertek to work with My HTPC and now have shortcuts, even autoplays.
    So WAF now.......................
  15. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Oh dear look at this:clap:
  16. Jeff
    Jeff
    Jul 13, 2000
    5,501
    Basingstoke
    +263
    :smashin:
  17. Kramer
    Kramer
    Still seems like a pain, all this "pointing, shortcuts" etc..
    What about the casual "ripper" - "timeshifting" rented DVDs etc...? I'm forever moving stuff around the network so mounting an .ISO is far easier.
  18. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Kramer, have a play with this m8, seems so easy now i've got over the hurdle of learning how to.
    Gonna be really brave and get a pair of 260gb hd and fill 'em up.
    I'll still drop all subtitles, and unwanted language tracks, just to help with space.
    As for the casual ripper, i'll try it tonight, seems well easy though.
  19. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Well I use a small utility called Daemon Tools (v3.29) which gives you a virtual DVD drive to which you can mount an ISO file using a friendly file open type dialog box.
    Couldn't be simpler really.
    Their site doesn't appear to be working at the moment but its:
    www.daemon-tools.cc/portal/portal.php
    Cheers, Lee
  20. Kramer
    Kramer
    Nice :smashin: Haven't ever "played" with myHTPC - will have a look.
    loonatic,
    Working fine here. Usually use Decrypter/Daemon for ISOs (DVD's I have rented but haven't had time to watch before return).
  21. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    I tihnk you need a '/' before PATH, ie. /PATH.
  22. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    There is a way to add an entry to the registry which specifies TheaterTek as the way to 'Open' an ISO image, not sure where to find that at the moment. Personally I use Alcohol or Daemon Tools to mount it, a tad more tedious but tolerable.
  23. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    KRaGorn
    Got it nailed with HTPC now, just have to decrypt to a My DVD file, then add a thumbnail and it is done.
    Could it be any easier?
    Oh and the wife played a ripped dvd this morning then listened to some music then checked the weather report, three or four clicks on a mouse. How is that for WAF.
    Rgds
  24. Kramer
    Kramer
    .....err, I don't know. Sounds kinda complicated :D
    Now get it fully "Prontoable". Gonna have to get Girdering/.ccfing/AximIRing soon.
    :smoke:
  25. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Now that is the next giant leap, wanted to get Netremote to work but may drop back to my Kamelleon 6 in 1.
    Still big improvement and a good excuse to get 1/2 a terrabite of hdd space :hiya:
  26. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Oh and will set up a password protected "for your eyes only" section to keep my more sensitive material, now can I click one handed
