Theatertek Crashes on disc insert
Discussion in 'Desktop & Laptop Computers Forum' started by minimivic, May 23, 2002.
  1. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Hi all,
    Just got my Theatertek after about 2 weeks wait and whenever a disc is inserted it locks computer and reboots.
    PC Win XP on Asus A7V266 with XP1700+ Etc.
    Radeon 8500 with 6058 drivers
    Sonic fury sound card
    I tried to disable hardware acceleration on graphics card and the player then went into "Video initialisation error" instead of crashing.
    Not sure what else to try and look for. Any ideas?
    Cheers.
  2. Jenz
    Jenz
    Are you using the latest version of TT (patched via files from ImmersiveInc Website)?
    Should be 1.2.
    Jenz
  3. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Version 1.2.076 so upto date.
    What drivers for radeon should i be using for Win XP.
    Just downloading 6071 from ATI to see what happens.
    Computer is very unhappy since the install of TT:(
    Slow, Lockups, BSOD ( unheard of on this PC ). Power DVD now stutters. So far unhappy.
    Any other ideas?
  4. fatrich
    fatrich
    Jun 21, 2001
    2,617
    71
    halifax
    +53
    Paul
    like Jenz says go on the immersive forum i have had a few problems myself of which they corrected, or send Andrew (chivz) an e-mail his details are again on the immersive forum
    hope u get it sorted because as most will agree on here the tt player is at the monent one of the best software players around especially with the support, good luck
    regards
    richard
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Sharky,
    At the Immersive support forum you'll find a post from me saying pretty much same thing was happening. I was using the most up to date drivers from ATI site.
    I was told to go and get a different, older set, from a guys web site. The link should be on the Immersive thing. You have to go through a major spot of bother uninstalling the previous drivers then re-installing the older ones! I followed the advice and it just started working.
    Gordon
  6. Ken
    Ken
    Dec 15, 2000
    372
    Stoke-on-Trent
    +13
    Using Windows XP, people have had the most success with the 6025 drivers.
    Ken
  7. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Had to do a reinstall of windows, just relly messed up my comp:(
    Installed 6025 drivers and TT and now its cant find any decoders.
    So i installed the ravisent decoders from the disc and still nothing happens. Checked in Contriol panel/ add-remove and the filters are there. All this and only the internet on the comp at moment so nothing is getting in the way or corrupting the OS.
    Help?
