Theatertek 2 audio options
Discussion in 'Desktop & Laptop Computers Forum' started by Jas, Nov 23, 2004.
  1. Jas
    Jas
    Jul 14, 2000
    87
    Lancs,Wigan
    Hi Everyone
    Might seem a silly question but i am fairly new to this HTPC lark , do i buy theatertek 2 with advanced audio options or without. as i am going to run optical out from my pc to my Denon amp digital optical input and let the denon do all the processing for all the obvious sound formats.
    I suspect i just need the basic theatertek2 but confirmation would be helpfull
    Thanks to all who may reply :thumbsup:
    Regards Jas
  2. joffonon
    joffonon
    Dec 4, 2002
    105
    Westcliff-on-Sea, Great Britain
    You suspect correctly, Jas. Basic TheaterTek is all you need if your amp is doing the processing.
  3. Jas
    Jas
    Jul 14, 2000
    87
    Lancs,Wigan
    Thanks just needed to see if my brain is still working correctly :clap:
    Regards Jas
